Star
Use this plug-in to create a Star with different attributes.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> Default
This section contains the following topic and procedure:
Star Properties
Corners/Tips: Set the number of corners on the inner circle of the star (equals the number of tips on the outer circle of the Star). Default: 5, Min: 3, Max: 300.
Star Radius: Set the radius of the outer circle (where the tips of the star are located). Default: 50, Min: 1, Max: 200.
Star Inner Radius Factor: Factor of the outer radius to the inner radius of the star. A value of 1.0 means that the inner radius of the star is identical to the Star Radius value. Default: 2, Min: 0.25, Max: 50.
Hole: Place a hole in the Star geometry. Default: 0 (Off).
Hole Radius: The radius of the outer circle where the tips of the hole are located. Default: 25, Min: 1, Max: 200.
Hole Inner Radius Factor: Ratio of the outer radius to the inner radius of the hole. A value of 1.0 means that the inner radius of the hole is identical to the Hole Radius. Default: 2, Min: 1, Max: 50.
To Create a Star
Create a new container.
Add the Star plug-in to it (1 (default Star)).
Open the Star editor.
Modify the Star parameters, for example (2).
Corners: 10
Star Radius: 60
Star Inner Radius Factor: 6.0
Hole: On
Hole radius: 50
Hole Inner Radius Factor: 9.0
If required, add a material and/or a texture.
