Control Objects
The Control Objects panel is used to show the control parameters for use Viz TRIO Scenes only.
Control Object Parameters
Main: Set to ON to view only the main control fields of the Control Object. Set OFF to view all fields
Unique: Click to enable view of only the original field if there is more than one field with the same identifier. Click again to disable view all fields, including field duplicates with the same name. This allows the designer to easily select the respective containers in the scene. By default, Viz Artist displays all fields in the scene.Control Objects: The Container which contains the control Object.
Description: Enter a description in the plug-in Properties panel.
Value: The editable plug-in value
Type: The type of Control Object
