Polygon
The Polygon Geometry plug-in enables the creation of user defined polygon shapes. The polygons are drawn and edited directly in the Scene Editor. Created Polygons can also be rotated to create a 3D object (see Revolve: Spline Rotation in 3D).
To create a Polygon, add the Polygon plug-in to a container and start drawing by clicking in the Scene Editor to create polygon nodes. A click, hold and drag converts the node into a spline handle for drawing curves. If an existing node is clicked on it removes the node, and if a line or spline is clicked on, between two nodes, it inserts a new node at this location. There are several Polygon plug-in Editor Shortcuts. If more than one polygon is created, in the same container, and if they overlap each other, they will act as masks.
Instead of drawing polygons manually, they can be imported as Adobe Illustrator files (*.ai) as well.
Note: Only Adobe Illustrator AI 88 format files are supported.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> Default
Polygon Properties
To toggle between the Polygon and Container properties:
Click the Polygon or Transformation icon in the:
Scene Tree Container, or
The Properties panel
In the Scene Editor:
Outside the polygon bounding box: Right click and select Properties -> Geometry.
Inside the polygon bounding box: Right click and select Edit container.
Precision: Set the precision of the spline calculation
Import: Import Adobe illustrator files. Opens a window to select a file and import. Only Adobe Illustrator AI 88 format files are supported.
Revolve: See Revolve: Spline Rotation in 3D
Storage: Create a Spline with coordinates. Press <Enter> to apply
Polygon Scene Editor Context Menu
Right-click, and hold, in the polygon green bounding box, in the Scene Editor, to open the polygon context menu. To select a menu option see To Select an Option from the Context Menu.
Note: The right-click must be inside the created polygon shape box. If a click is outside the bounding box then the standard Scene Editor menu will be shown.
New spline: Create a new polygon in the same container
Close/Open: Open or close a polygon
Cut: Cut the selected polygon or spline nodes
Copy: Copy the selected polygon or spline nodes
Paste: Paste the selected polygon or spline nodes
Mirror X/Mirror Y: Mirror the created shape in the X or Y axis
Flip x/Flip y: Flip the created shape in the X or Y axis
Edit container: Open the Container editor and exit polygon edit mode. To edit the polygon again click on the polygon icon in the properties editor or the Scene Tree
Right-click and hold.
Move the cursor to the required option.
Release to select.
Create a Polygon
To Create a Simple Spline
Create a Container.
Add the Polygon plug-in.
Click on the Polygon icon (in the Container or the Properties editor).
The polygon splines are created by each click in the Scene Editor:
Click in the Scene Editor to create a spline point
Click and drag in the Scene Editor to create a spline node, complete with handles (continue the drag to increase the length of the handles)
While the polygon plug-in is active each click in the Scene Editor will create more polygon points, and create the polygon shape.
Tip: At any time press and release <Delete> to remove the last created point. Press and hold <Delete> to remove more than one spline, or remove the whole polygon.
Once the spline has been created it can be modified, as required, with various shortcuts (see Polygon plug-in Editor Shortcuts). List below are some common examples:
To Draw a New Spline
Right-click in an existing spline.
Click New Spline.
Add intersections as detailed in To Create a Simple Spline.
To Move a Spline
Select the spline to be moved:
Press <S> and click on a spline.
Press <Alt> and drag.
Tip: If there is only one spline in the Container, press <Alt> and drag.
To Move More Than One Spline
Select the splines to be moved:
Press <S> and drag around the splines.
Press <Alt+S> and drag.
To Add or Delete a Spline Point
Click anywhere on a spline to add another spline point.
Click on a spline point to delete it
To Move Spline Points
Press and hold <Ctrl>.
Click on a spline point and drag.
When <Ctrl> is pressed move any spline points as required.
To Create or Delete a Spline Point Handle
Press <Shift>:
Create: Click on a spline point and drag.
Delete: Click on a spline point with a handle.
To Resize a Spline Point Left or Right Handle
Press <Shift>.
Click on a spline point handle and drag. Only the selected handle will move.
To Resize a Spline Point Handle
Press <Ctrl>.
Click on a spline point handle and drag. The left and right handles will move as one handle.
Note: The handle clicked on can be lengthened as required. The other handle will stay the same length
Note: If either the left or right handle has been moved individually, this will set the two handles together again
To Mirror Spline Sections
Right-click on a spline, or select particular nodes of it with <S>.
Select either:
Mirror X: Mirrors whole spline along the X axis.
Mirror y: Mirrors whole spline along Y axis.
To Flip a Spline
Right-click on a spline.
Select either:
Flip x: Flips whole spline over X-axis.
Flip y: Flips whole spline over Y-axis.
Scene Editor Grid
The Scene Editor Grid Tool-bar can be used as a great tool to help draw polygons. Together with the grid snap option polygon points can positioned, simply and accurately, in the 3D space.
Make sure that the polygon is aligned with the grid for the grid snap to work.
To Create a Spline in the Scene Editor Grid Snap
In the Scene Editor click
(Grid).
Click
(Plane Type).
Click
(Free Grid).
Click
(Snap to Grid).
Create a spline. Each spline point will snap to the nearest cross hairs on the grid.
To Move a Spline in the Grid with Snap
(Grid).
Click
(Plane Type).
Click
(Free Grid).
Click on
(Move Object to Plane).
Press <Alt>.
Click on the Spline and drag.
Note: If there is more than one Spline to be moved see To Move More Than One Spline.
The Spline will snap to the next set of cross hairs, and so on, as it is dragged.
The Spline rotation creates a 3D mesh by rotating the created spline.
Use the Polygon Revolve Properties panel to modify the Spline as required.
The Polygon Revolve properties are available after the first spline point has been added to the Scene Editor. Click on Rotate to activate.
Rotate: Click to create the revolve mesh and activate all its settings
Rotate in degrees box: Set the degree of rotation
Tessellation: Sets the degree of detail for the mesh
Shading Angle: Define how the shading normal are aligned on the revolve object surface
Culling: Set which side of the spline to view:
Back: View the back side of the spline
Front: View the front side of the spline
Note: To view both sides at the same time, add the Expert plug-in to the Container and active Back Face.
Revolve Around: Set the axis to rotate the spline around
Local Axis: When the Rotation angle is changed the rotation is calculated around the Container axis
First to Last: When the Rotation angle is changed the rotation is around the first and last spline point (Revolve Axis is grayed out)
Revolve Axis: Set which axis to rotate around:
Y: The rotation is around the Y axis
X: The rotation is around the X axis
Direction: Set which direction to view the rotation:
Right-hand: View from the right hand side
Left-hand: View from the left hand side
Show Hull: Show the rotated shape (1 and 2)
Show Caps: Show the original polygon shape at the beginning and end of the rotation (1 and 3)
To Rotate a Spline
Create a spline.
Click on Rotate.
Modify the created 3D object with the Polygon Revolve Properties.
