Media Asset Panel
This panel contains parameters and settings for Media Assets. There are different types of Media assets available like Clip Channels, GFX Channels, Image Channels, Live Input Channels, IP Stream Channels and Super Channels. In the image below you can see section 1 which is shared along all Media Assets, section 2 from below is individual depending on the used Media Asset. You can find the details for the individual Media Asset settings from section 2 in the user manuals individual chapters where the different types of Media Assets are described in detail.
Common Media Asset Properties
Item |
Description |
1 |
2 |
Clip Channel Properties / Live Channel Properties / IP Stream Channel Properties / GFX Channels Properties, Image Channels Properties |
3 |
Global Settings (section 1)
These are the common Media Asset properties.
VBI Source: Select which channel to use for output. Types of data sent include closed captions, teletext, time codes and other digital data. The configuration setting Clip Timecode Type enables Viz Engine to provide additional time code data in the VBI-signal, if required. The setting can be changed by editing the Viz Configuration file and setting the variable clip_timecode_type = <VALUE>. Please refer to the table Clip Time Code Type values below for valid values. It can also be set on the fly using the Send application to issue the following command: CONFIGURATION*CLIP_TIMECODE_TYPE SET <VALUE>
Note: This setting only applies for installations utilizing Matrox cards.
Note: If you are using more than one specific Media channel in your scene, just click on the the text of "CLIP1" (in section 1) and you can switch to the other clip channels used in the same scene.
Zero Frame Delay Mixer: Set to On to give the shortest input to output delay, with graphics on top. For this to work correctly, specific values for H-/V- phase must be set. For the input/output configuration, input A is bound to output A, and Input B is bound to Output B. Please observe that the resolution of the input is required to be the same as for the output. If running a Dual Channel setup, make sure that input A and input B are 100 % in sync, and using the same resolution.
Refer to H-/V- Phase Values for Zero Frame Delay Mixer for further information -
Show DVE Channels: Enable or disable DVE placeholder box drawing
Clip Channel on set:
Play on: By default, a clip channel continues to play the clip even if the Scene does not contain that specific channel. When setting a Scene with this channel active, the clip will be shown from its current position onwards, when no clip or the same clip is set in the Scene.
Reset: Playout will start from the beginning of the clip when it has the same clip name, or show black when no clip is set in the channel at all.
Please observe that the commands and values are case sensitive. Any on-the-fly changes will be saved to the Viz Configuration file upon proper shutdown of Viz Engine.
Caution: Manual changes to the Viz Configuration file should never be made while Viz Engine is running. Close the engine, commit any changes, and start the engine. Make sure to always create a backup copy of the Viz Configuration File before making any manual changes.
Basic: This setting is used to transform the whole used Media Channel.
Content: This setting is used to transform the content inside the used Media Channel.
Position: The position controls are used to set the X and Y coordinates for the Media Asset. The coordinates are relative to the configured output format (see the section Configuring Viz in the Viz Engine Administrator’s Guide).
Size: Set the X and Y values to define the size of the Media Asset. The size is based on the channel resolution as defined in the Video Input section of Configuring Viz (see the Viz Engine Administrator’s Guide), which may be different than the configured output resolution.
Center: Use the Center X and Y values to define the center position of the Media Asset. As for the Size control, the Center position is relative to the configured channel resolution.
Absolute / Relative Position Controls: Controls to adjust the Position, Size, Center position, and Crop. The values can be provided either as Absolute pixel values, or as Relative percentage values. The corresponding value will be displayed next to the input value field. If provided with values that exceed the logical limit, the last value will be adjusted automatically to the maximum value. For example, if setting the Left crop value to 51 %, and then the Right crop value to 75 %, the Right crop value will be set to 49 %. Applies to DVE only.
Note: By default, the center position for DVE transformations is defined as the top left corner of the DVE placeholder. Setting the DVE Center X and Y positions to 50 % will define the center for the transformations as in the middle of the DVE placeholder. This behavior deviates from that of transforming Containers, as they have their transformation center in the middle.
Crop: Allows the designer to crop the Media Asset as required. The crop values are relative to the size as defined using this editor.
Forward Transformation: The transformations will be forwarded to the container which was dragged & dropped to this parameter. The transformation is mapped to the XY plane of the container. This allows a video wall control application like Viz MultiPlay to control virtual (3D) Video Walls as well. This applies only to Media Assets added as Texture, and the Forward Transformation controls will only be visible for selected Texture Media Assets.
Identifier: The name of the target container.
Active: Forwarding is active.
Reset: Resets forwarding to the specified container.
For Matrox X.mio2, DSX.LE2 and DSX.LE3 video boards:
PAL: Leave the values at the default
NTSC: Leave the values at the default
720p50: Valid H-Phase range from -900 to -1300
720p59.94: Valid H-Phase range from -600 to -1000
1080i25: Valid H-Phase range from -1600 to -2000
1080i29.97: Valid H-Phase range from -1100 to -1600
Media Asset Clip Settings
In addition to the common Media Asset properties, Video Clip also has these properties
Clip: Select the video clip to be shown:
In the Clip line, click
, or -
Drag a Video Clip item from the Server Panel, or
Click
, and select a video clip to import. Note: See Transfer Clips From Viz One. To transfer and download videos from Viz One, Viz One must be integrated and configured with Viz Artist/Engine.
Note: With the Clip Channel Media Asset it is possible to play images as DVE or Texture with the Matrox clip player. Supported image containers are jpg and png. The images have to be available on a physical disk for this feature to work.
Active Clip/Pending Clip: The status of active and pending clips:
Green light shows that the clip has loaded successfully.
Grey light shows that no clip has been loaded.
Red light shows that there was an error during the clip loading process.
In Time: Set the video clip ‘in time’.
Out Time: Set the video ‘out time’.
Clip control: Player controls for the selected clip.
Autorun:
Off: As soon as the video clip is loaded, the first frame is presented.
On: As soon as the video clip is loaded, it begins to play.
Loop Mode:
Off The video clip will play only once.
On The video clip will play in a loop.
Reverse Field: As interlaced video contains two fields of a video frame, reverse playback of interlaced video can result in flickering unless the fields are also played back in reverse. On the Video version of Viz Artist and Engine with Matrox video hardware, Reverse Field is automatically enabled when playback speed is given a negative value.
Off: During reverse playback, the fields in interlaced mode are played out ‘as is’.
On: During reverse playback, the fields in interlaced signals are swapped to reduce flicker.
Upscale Luma:
Off: The key will be used ‘as is’.
On: The key information will be upscaled from 16-235 to 0-255.
Repeat Mode:
None: The playback of black frames when the clip is in an erroneous state.
Field: The first field of the last frame will be played out when the clip is paused.
Frame: The last frame will be played out when the clip is paused.
Speed: Controls playback speed. 1.0 is the normal speed. Values between 0 and 1.0 are forward playback in slow motion. Values above 1.0 are forward playback in fast motion. Likewise, values between 0 and -1.0 are reverse playback in slow motion. Values less than -1.0 are reverse playback in fast motion.
Audio: Set the Audio volume
Alpha: For each layer adjust the level of opacity. A value of 100 % is fully opaque and 0 % is fully transparent.
Value |
Description |
DEFAULT |
Mimics the behavior of earlier versions, and will provide a time code if available. If not, no time code information is provided in the VBI-signal |
TIMECODE |
Will provide a time code if available. If an explicit time code is not embedded in the clip, no time code information will be provided in the VBI-signal |
ZEROBASED |
The embedded time code will be ‘0’ at the clip start and count up to the last frame, based on the number of frames in the clip |
COUNTDOWN |
The embedded time code will be the duration of the clip at the beginning and countdown to ‘0’, based on the number of frames in the clip. |
Media Asset Keying Settings
In addition to the common Media Asset properties, Keying has these properties.
Keying Mode (Texture only: see Keying Mode):
Linear: No chroma keying
Chroma: Uses the internal chroma keyer
M-Zone: Uses the multi-zone keyer
Libero: Uses the Viz Libero keyer
Invert: Only works with Chroma and Libero
Talent Reflection: Click to set Talent Reflection On or Off (use with Viz Virtual Studio):
Offset: Set the offset of the talents lowest body part from where the reflection starts (pixels (Default: 0, Minimum: 0, Maximum: 1000))
Extend: Set the extend of the total reflection (pixels). The reflection eases out with distances (Default: 300, Minimum: 0, Maximum: 1000)
Person Scale: Set a global scale which applies to the talent (Default: 1, Minimum: 0.2, Maximum: 10)
Damping: Set how many previous fields are to be used to calculate the current Y position. The larger the number the higher the damping, but the Y coordinate will be less responsive to quick movements. The setting is a compromise between a stable and a non-responsive Y coordinate for the reflection (Default: 2, Minimum: 2 Maximum: 100)
Key Scale: Set the scale applied to the alpha of the reflection, on top of the parameters set in Offset (Default: 0.5, Minimum: 0.1, Maximum: 10)
Distortion X / Y: Parameter X defines by how much x axis is affected by the sinus distortion which goes vertically down the screen (Default: 1, Minimum: 1, Maximum: 10). Parameter Y defines how much the sinus waveform is stretched vertically down the reflection (Default: 0, Minimum: 0.001, Maximum: 1)
Brightness: Set the brightness for video going through the chroma keyer (Default: 0, Minimum: 0, Maximum: 10)
Live Properties
The Live video properties are listed in the common Media Asset properties.
Stream Properties
In addition to the common Media Asset properties, Video Stream also has these properties:
URL: Enter the URL of the Stream to be shown (Video Stream only):
Load: Click to load the video Stream
Clear: Click to remove the video Stream.
Repeat Mode:
None: The playback of black frames when the stream is in an erroneous state
Field: The first field of the last frame will be played out when the stream is paused
Frame: The last frame will be played out when the stream is paused
GFX Properties
By default, a GFX Channel automatically inherits the camera settings of the Scene it is applied to. In addition to the common Media Asset properties, GFX Channels also have the following properties:
Scene: Drag a scene, which should be rendered in the GFX channel
Play Controls: Control the animation of the set scene
Controlled: If activated the GFX Channel animation can be controlled by the main or parent Scene animation controls, for example, if the animation in the main Scene starts, it triggers the start of the GFX Channel Scene
Force Key: If a GFX channel is rendered as Texture, it will be in RGBA. Therefore, the Scene needs to have keying information for an alpha channel (the key scene setting is set to auto key or a key plug-in is used in the Scene Tree). If the Scene does not have any keying information, enable Force Key to render the whole Scene keyed
Keep Aspect: If On the GFX Scene is rendered with its own aspect ratio (undistorted). If Keep Aspect is Off then the Scene will be scaled to fit the GFX channel size.
Camera: Select the camera view of the GFX Channel Scene.
Resolution: The GFX Channels will default to the resolution configured for the current Output Format in the Viz Engine configuration. To change the current resolution, click the Default Resolution button to make the Resolution X and Y fields available for input, and enter the desired resolution setting. Clicking the Default resolution again will reset the resolution for the GFX Channel, as well as disable the Resolution X and Y input fields. If the Default Resolution button is in a pressed state, and the Resolution X and Y fields are dimmed, the default resolution is in use.
Note: The resolution setting only applies to GFX Channels in Texture mode.
To View Media Asset (DVE or Texture) Properties
Add a Media Asset as DVE or Texture to a Scene.
In the Media Asset Manager select DVE or Texture (to view the added Media Asset)
Click on the required Media Asset.
Note: DVE or Texture view: If a Media Asset has been added to a Scene, its properties can also be selected by a <right-click> on the Media Asset icon in the Media Asset list (Built Ins), and select Show settings of <clip channel>.
To View Media Asset (Texture) Properties
Right-click on the Media Asset icon in a container and select Show settings of 'media asset type'.
or:
Click on the Media Asset icon in the Container.
In the Texture Editor click on the Media Asset image icon.
In the properties panel the Media Assets tab is automatically selected, and the Media Asset Manager (Scene Tree panel) opens.
