Text FX Arrange
The Text FX Arrange plug-in allows you to arrange characters in either a circular- or a wave shape. The characters can be animated on the selected shape by animating the offset value.
Text FX Arrange Properties
Offset %: Moves the characters on the shape. 100% means one full rotation of the text on the circle.
Scale %: Sets the text on the shape. The parameter does not scale the characters itself, but the kerning of the characters.
Shape: Changes the shape of the character layout to Circle or Wave.
Note: The shape of the text transformation is not visible in the Scene Editor while the Text Editor is active.
Circle Parameters
Diameter: Set the diameter of the circular shape
Positioning: Define the position of the text on the circular shape:
Relative: The text spacing of the text object is maintained
Absolute: The text is evenly distributed out on the circle
Direction: Set the direction of the text on the circle to either:
Clockwise, or
Counterclockwise.
Rotation: Rotate the characters on the X-axis
Align: Rotate the characters on the Z-axis to align the X-axis with the tangent of the shape at the characters position
Wave Parameters
Length: Set the wave length. A high value creates many and small waves, a low value creates fewer and bigger waves
Width: Set the width of the wave
Height: Set the height of the waves without altering the number of waves as the Length does
Shift %: The wave usually starts at the height 0. The shift value moves that point, thereby moving the texts position on the wave structure. Setting Shift % to 100% brings you back to the beginning
Damping: Can be used to modify the amplitude of the wave curves
