Viz Artist/Engine Folders
This section details the location of the Viz Artist/Engine default installation and data folders.
User Account Control (UAC) in the Software Configuration section of the Viz Engine Administrator Guide.
Installation Folders
The default installation folders for Viz Artist and Engine are:
Windows System |
Viz Artist/Engine Platform |
Installation Folder |
Windows 32-bit |
32 bit |
C:\Program Files\vizrt\Viz3 |
64 bit |
N/A |
Windows 64-bit |
32 bit |
C:\Program Files (x86)\vizrt\Viz3 |
64 bit |
C:\Program Files\vizrt\Viz3\C:\Program Files (x86)\vizrt\Viz3Gui |
On 64-bit platforms, the user interface is installed in a 32-bit folder, as it is a 32-bit application. In this User Guide, any reference to the Viz Artist and Engine installation folder is replaced with the text <viz install folder>.
Note: Viz configuration files that already exist from a previous installation are automatically copied on install time if the installation folder did not change. If Viz Engine/Artist is installed in a different installation folder then Viz configuration files must be manually copied from the old installation folder to <viz data folder>.
Data Folders
Files which are created or modified by Viz Artist and Engine are located in %ProgramData%\vizrt\viz3. By default, this is C:\ProgramData\vizrt\viz3. This folder is referenced as <viz data folder> throughout this User Guide. The folder contents include:
Viz configuration files,
Script plug-ins,
Crash dump files.
Temporary files are located in %TMP%\vizrt\viz3, which usually resolves to C:\Users\<user name>\AppData\Local\Temp\vizrt\Viz3. This folder is referenced as <viz temp folder> throughout this User Guide.
Script plug-ins are located in the <viz data folder>\ScriptPlugins subdirectory.
Note: Script plug-in files that already exist from a previous installation are automatically copied on install time if the installation folder did not change. If Viz Engine/Artist is installed in a different installation folder, then Script plug-in files must be manually copied from the old installation folder to <viz data folder>\ScriptPlugins
