Radial Blur
Use this plug-in if you want to blur the object in different ways.
The samples above depict the same image with radial blur quality set to Low, Normal, High and Very High with Center X and Y set to -25.0 and 25.0, Inner Range and Scale set to 25.0 and 50.0, respectively.
Note: Radial blur does not clamp the object.
Note: This plug-in is located in: Built Ins -> Shader -> Filter
Radial Blur Properties
Quality: Sets the quality of the blur filter. Low will be more pixelated, whereas very high will be smooth. Available options are Low, Normal, High and Very High.
Center X and Y: Sets the position of the object’s radial blur.
Inner Range: Sets the inner range of the blur.
Scale: Sets the scale of the object’s blur.
