Built Ins
In Built Ins there are a standard set of Viz Artist installation plug-ins.
Most plug-ins can be added to Containers, except, for example, Scene plug-ins. Because Viz Artist uses an open interface for the plug-ins, new geometries can either be obtained or created and then installed with Viz Artist. Also, most plug-ins have a properties editor. When a plug-in is applied to a Container in the Scene Tree, a plug-in icon will be added to the target Container.
The Built Ins button on the Main Menu gives access to the various plug-ins:
Content Tabs
The Built Ins are contained under various tabs and in folders.
Geometry plug-ins (GP)
Container plug-ins (CP)
Shader plug-ins (SH)
Scene plug-ins (SP)
Media Assets (MA)
Click on a Built In tab to open its panel and folder list. Double-click a Built In tab to open its panel and go to the default folder in the folder list. Default folders are:
Geometry plug-ins (GP): Default
Container plug-ins (CP): Global
Shader plug-ins (SH): Default
Scene plug-ins (SP): Default
Media Assets (MA): Channel
Plug-in Context Menu
A right-click on a plug-in icon to open the plug-in context menu.
Geometry, Container and Shader Menu
Add to Container(s): Add the selected plug-in to a Container(s).
Add as Favorite: Add the selected Texture to the Favorites Bar.
Delete from Favorites: Delete the selected Texture from the Favorites Bar.
Scene Menu
Add to Scene: Add the selected plug-in to a Scene.
Remove from Scene: Remove the selected plug-in from a Scene.
Media Asset Menu
Add <Media Asset> as Texture: Add the selected Media Asset to a Scene (automatically adds a new Container).
Add <Media Asset> as DVE: Add the selected source as DVE.
Show settings of <Media Asset>: Show the settings of the Media Asset, if it has been added to the scene and the Scene Tree is in Texture or DVE view.
Add as Favorite: Add the selected source to the Favorites Bar.
Delete from Favorites: Delete the selected source from the Favorites Bar.
For the Background and Foreground media assets, the context menu shows the Favorite options only.
View and Search for plug-ins
All plug-ins can be dragged straight into the Scene Tree (except Scene plug-ins). Double-click a folder tab to go to the Default folder for that plug-in category.
To View plug-ins
Select Built Ins.
Select the appropriate plug-in category, either:
From the drop-down menu that shows above the plug-ins view, or
Click on of the tabs, or
<Ctrl+1>: Geometry plug-ins
<Ctrl+2>: Container plug-ins
<Ctrl+3>: Shaders
<Ctrl+4>: Scene plug-ins
<Ctrl+5>: Media Assets
The All folder in the left panel, offers an uncategorized view of all plug-ins. Pressing a letter on the keyboard to jump to a plug-in which starts with that letter.
To Search for a plug-in
You can drag plug-ins from the search results to the desired destination.
Select Built Ins.
Open the plug-in search panel, by opening the Built Ins drop-down menu and selecting Search..., or pressing <Ctrl+F>.
Enter a search string and click on Go (4), or press <Enter>.
Add Plug-ins to Containers
Most plug-ins can be dragged to a target Container(s) in the scene tree (1), the Properties Panel (2) or the Scene Editor (3). Each plug-in also has a context menu where a plug-in can also be added to a Scene.
To Add a Geometry plug-in
A Container can only contain one Geometry plug-in at a time. If a new Geometry plug-in is added the fist one will be removed from the Container.
Drag the Geometry plug-in icon to either:
A Container or multi selected Containers
The scene tree area (creates its own container)
The Scene Editor area
The Container Editor area
or
Highlight the target Container(s)
Right-click the plug-in icon and select Add to Container(s) from the plug-in context menu
To Add a Container plug-in
Drag the Container plug-in icon to either:
An object in the Scene Editor (only some container plug-ins will do this, when they will the object becomes active when the icon is moved over the object.
or
To Add a Shader
A Container can only contain one Shader at a time. If a new Shader is added the fist one will be removed from the Container.
Drag the icon to either:
or
To Add a Scene plug-in
Open the Scene plug-in tab:
Click on Scene Settings -> Plug-in
Click on the Scene plug-in icon (1). When a scene plug-in has been applied to the scene, this icon will turn to orange
Drag the Scene plug-in icon to the Scene drop area.
or
Right-click the Scene plug-in icon to open the plug-in context menu.
Click on Add to Scene...
To Add a Plug-in to Multiple Containers
Highlight the required Containers.
Drag a plug-in icon to a highlighted Container
Release the plug-in icon.
or
Drag a plug-in icon.
Hold the plug-in icon over a Container.
Continue to hold the left-click and do a right-click to drop the plug-in icon on the Container.
Continue to hold the left-click and repeat for each required Container
To Add a Plug-in to Favorites
Right-click the icon to open the plug-in context menu.
Click Add as favorite...
You can also add plug-ins as favorites from the search panel.
To Open a Plug-in Properties Editor
Click on the Media Asset icon, in the Container or the in the Properties Editor.
