Viz Plug-ins User Guide
Text FX Scale
The Text FX Scale plug-in allows you to create a scaling animation of the characters.
Supported Pipelines |
Classic Render Pipeline |
Viz Engine Render Pipeline |
Text FX Scale Properties
Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
Anchor Vertical: Sets the anchor point for the characters on the vertical plane.
Use Axis: Defines on which axis or axes the characters scale.
Lock Axis: Scales the Begin- and End the same for all the axes when enabled. If you disable the parameter, Begin and End must be set for all the axes individually.
Begin: Sets the initial size of the characters.
End: Sets the ending size of the characters.
