Viz Plug-ins User Guide
Text FX Jitter Scale
images/download/thumbnails/95402167/ico_tfx_js.png
The Text FX Jitter Scale plug-in animates a jittering effect on the scale of the character.
Supported Pipelines
Classic Render Pipeline
images/s/-wjspee/8703/98yf4s/_/images/icons/emoticons/check.svg
Viz Engine Render Pipeline
Text FX Jitter Scale Properties
  • Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
  • Anchor vertical: Sets the anchor point for the characters on the vertical plane.
  • Use Axis: Defines on which axis or axes the characters scale to create the jittering effect.
  • Lock Axis: Gives all the axes get the same Min, Max and Randomness settings when enabled. If you disable randomness, these parameters are visible for each of the axes and must be set individually.
  • Min: Sets the minimum scaling for the characters.
  • Max: Sets the maximum scaling for the characters.
  • Randomness: Sets the intensity of the jittering movement.
