Viz Plug-ins User Guide
Text FX Rotate
images/download/thumbnails/95402173/ico_tfx_rotate.png
The Text FX Rotate plug-in allows you to create an effect where the characters rotate on the X-, Y- or Z-axis.
Supported Pipelines
Classic Render Pipeline
images/s/-wjspee/8703/98yf4s/_/images/icons/emoticons/check.svg
Viz Engine Render Pipeline
Text FX Rotate Properties
  • Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
  • Anchor Vertical: Sets the anchor point for the characters on the vertical plane.
  • Use Axis: Defines on which axis the characters rotate.
  • Begin: Sets the initial rotated position of the characters.
  • End: Sets the ending rotated position of the characters.
