Viz Plug-ins User Guide
Ring
images/download/thumbnails/114312021/ico_ring.png
The Ring plug-in creates an open or closed ring with some attributes.
Ring Properties
  • Use LOD: Enables/disables dynamic level of detail.
  • Corners: Sets the number of corners on the ring.
  • Inner Radius: Sets the size of the inner radius.
  • Outer Radius: Sets the size of the outer radius.
  • Rotation: Rotates the ring like a “turning wheel”. This is typically used in combination with an open angle, to place the angle at the required point.
  • Angle: Defines an open angle on the ring.
  • Mode: Changes the object view coordinate. Available options are XY, XZ and YZ.
To Create a Ring
images/download/attachments/114312021/pg_ring_x.png
  1. Create a new group and add the Ring plug-in to it.
  2. Add a material and/or a texture to the group.
  3. Open the Ring plug-in editor and animate the Angle.
    • Set Angle to 0.0 (60/50 fps).
    • Set Angle to 360.0 (120/100 fps).
