Viz Plug-ins User Guide
Magnifier
images/download/thumbnails/85896572/image2020-7-13_12-55-27.png
The Magnifier plug-in enlarges certain areas of the render output. This plug-in magnifies all underlying graphics. Create a container and drag the Magnifier plug-in on it. It automatically magnifies the underlying parts. It can be used multiple times (in contrast to the scene magnifier functionality).
images/download/attachments/85896572/image2020-6-26_10-49-7.png
Compatibility Info: This plug-in works in the Viz Classic Render Pipeline only and only is available if the Render mode is set to Classic.
Magnifier Properties
images/download/thumbnails/85896572/image2020-6-26_10-46-57.png
  • Type: Defines the basic shape of your loupe. It can be either a rounded circle or a square rectangle shape.
  • Position: Defines the location of the maginfication. This can be either defined in the plug-in itself by modifying the x and y parameters or you use the attached containers position by activating the Use container position option.
  • Size: Defines the location of the maginfication. This can be either defined in the plug-in itself or you use the attached containers scale by activating the Use container scale option.
  • Scale: Determines the magnification level.
  • Ellipsis: Defines how much distortion the lens has.
  • Alpha: Gives your magnifier a smooth border. A value of 1 gives a sharp edge and the lower the value, the smoother the edges are.
  • Tesselation: Defines how exact the loupe is build. A value higher than 20 does not make any sense and provides no visual improvement.
