XML Import Settings
  • Path of Primary Event Nodes: Path to the element that contains the primary events.
  • Secondary Events Nested in Primary Events: Check this box if secondary events are nested as child elements within primary event nodes.
  • Path of Secondary Event Nodes: Path to the element that contains the secondary events.
  • Channel name is defined at the root level: Assumes that the channel name is defined as a meta data entry (at the root level) outside the primary element entries.
  • Playlist date is defined at the root level: Assumes that the playlist date is defined as a meta data entry (at the root level) outside the primary element entries.
