Excel Import Settings
  • Header Lines Included: If checked, the header lines will not be read, and reading will start from the first row of data only. If left unchecked, the first line will be read. Only relevant if the import type is Excel (*.xls or *.xlsx).
  • Skip Rows: Set the count here if the Excel file contains any blank lines after the header-line that need to be skipped.
