GET All Channels
Returns a list of channel-definitions.
Syntax
GET /config/channelsRequest
GET /config/channels HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/vizrt.promoserver+xml; type=channelsList<promoserver:channelsList xmlns:promoserver="http://www.vizrt.com/promoserver"> <promoserver:channelItem> <promoserver:refLink rel="self" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/Test" /> <promoserver:refLink rel="edit" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/Test" /> <promoserver:refLink rel="machineaddresses" type="application/vizrt.promoserver+xml; type=machineAddressesList" href="http://localhost:9980/config/channels/Test/machineaddresses" /> <promoserver:name>Test</promoserver:name> </promoserver:channelItem> <promoserver:channelItem> <promoserver:refLink rel="self" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/TestCross" /> <promoserver:refLink rel="edit" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/TestCross" /> <promoserver:refLink rel="machineaddresses" type="application/vizrt.promoserver+xml; type=machineAddressesList" href="http://localhost:9980/config/channels/TestCross/machineaddresses" /> <promoserver:name>TestCross</promoserver:name> </promoserver:channelItem></promoserver:channelsList> Disallowed Actions
This end-point does not allow PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
