Attribute Mappings
Predefined Attributes
images/download/attachments/130555939/image-2023-6-19_19-27-0.png
  • Column Name: Specify what attribute name to show on the playlist.
  • Attribute: All attributes in this column are used in Page Content Filling Dialog, Rules condition and Filtering Options.
  • Editable: If value can be edited when shown in Playlist.
Metadata Attributes
images/download/attachments/130555939/image-2023-6-19_19-27-50.png
In addition to the columns above there is also:
  • Attribute Type: In what kind of events this attribute is found.
The option Get metadata from playlists triggers the client to examine all playlists in the channel and find all attributes in primary and secondary events. Automatically adds all attributes in the Playlist Data Mapping table with a blank Column Name. To show this attribute in the playlist column (option Use External Data menu when right-clicking on playlist column), you must fill in a Column Name.
