GET Channel Action Pool (Version 2.0)
Get all actions in the channel action pool.
Syntax
GET /api/channels/[channel]/action_poolRequest
GET /api/channels/test/action_pool HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/vizrt.integrationshubv2+xml; type=list<inthub:list xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="inthub:actionsList" xmlns:inthub="http://www.vizrt.com/integrationshub"> <inthub:action> <inthub:name>viz_continue</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=action" href="http://127.0.0.1:9991/api/channels/test/action_pool/viz_continue" /> <inthub:description>Continue (Stage)</inthub:description> </inthub:action> <inthub:action> <inthub:name>viz_continue_front</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=action" href="http://127.0.0.1:9991/api/channels/test/action_pool/viz_continue_front" /> <inthub:description>Continue (Front Layer)</inthub:description> </inthub:action> <inthub:action> <inthub:name>viz_start_animations</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=action" href="http://127.0.0.1:9991/api/channels/test/action_pool/viz_start_animations" /> <inthub:description>Start Animations (Stage)</inthub:description> </inthub:action> <inthub:action> <inthub:name>viz_show_begins</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=action" href="http://127.0.0.1:9991/api/channels/test/action_pool/viz_show_begins" /> <inthub:description>Show 0.0 (Stage, Back Layer)</inthub:description> </inthub:action> <inthub:action> <inthub:name>viz_cleanup</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=action" href="http://127.0.0.1:9991/api/channels/test/action_pool/viz_cleanup" /> <inthub:description>Cleanup</inthub:description> </inthub:action> <inthub:action> <inthub:name>viz_engage_video_bypass</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=action" href="http://127.0.0.1:9991/api/channels/test/action_pool/viz_engage_video_bypass" /> <inthub:description>Engage video bypass</inthub:description> </inthub:action> <inthub:action> <inthub:name>viz_disengage_video_bypass</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=action" href="http://127.0.0.1:9991/api/channels/test/action_pool/viz_disengage_video_bypass" /> <inthub:description>Disengage video bypass</inthub:description> </inthub:action> <inthub:action> <inthub:name>initialize_action</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=action" href="http://127.0.0.1:9991/api/channels/test/action_pool/initialize_action" /> <inthub:description>Initialize Playlist</inthub:description> </inthub:action> <inthub:action> <inthub:name>cleanup_action</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=action" href="http://127.0.0.1:9991/api/channels/test/action_pool/cleanup_action" /> <inthub:description>Cleanup Playlist</inthub:description> </inthub:action></inthub:list>Disallowed Actions
This end-point does not allow POST, PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
