LST Import Settings
images/download/attachments/125460965/configuration_lst-import-settings.png
  • Use Reconcile key as Viz One House Id: After a playlist has been imported, the reconcile keys are used to set the IDs for the Viz One assets.
  • Get date from schedule file: If the Schedule File Name (see Mapping Settings) is empty, the schedule date will be retrieved from the ADC-100 system’s RCV file.
  • Code Page: During import, bytes in an LST file, stored in the TITLE field, will be converted according to the defined Windows code page. For example, code page with identifier 1256 will convert bytes to ANSI Arabic.
  • Use Universal Sercom Driver: Enable this when USD is used.
  • Universal Sercom Driver name: If left empty, exports Secondary Events as standard secondary events for Harris. If defined, exports secondary events as macro commands for that Universal Sercom Driver (USD) device for Harris (ID=USD_NAME, Title=VIZRT:Media ID, Reconcile Key=Template_name).
  • Macro Name: Sets the macro name used in the Harris system.
