Trio Scroll item
The Trio Scroll item plug-in is used for data storage by the Trio Scroll Geometry plug-in. It is automatically added to each base item of a Viz Trio scroll scene.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> Default
Trio Scroll Properties
Prototype: Sets the path and the name of the scene.
Extra space before item: Sets the space before the item.
Extra space after item: Sets the space after the item.
Easepoint 0-4 enabled: Enables the easepoint(s).
Identifier: Sets the identifier for the easepoint.
Slow down length (EaseOut): Sets the size in pixels that will be used to ease out the scroll item.
Speed up length (EaseIn): Sets the size in pixels that will be used to ease in the scroll item.
Pause time in seconds, or -1 (indefinitely): Sets the time in seconds for how long the scroll should wait before continuing the scroll.
Note: This will affect the total time the scroll is scheduled to use.
Item alignment (0.5 for center): Sets the alignment of the item relative to the height of the item. 0.5 (equal to 50%) is the default value and represents the middle of the item’s bounding box area.
Scroll area alignment (0.5 for center): Sets the scroll alignment for the item in the scroll area. 0.5 (equal to 50%) is the default value and represents the middle of the scroll’s bounding box area.
Create New Scroll in the Viz Trio User Guide
