Stage Shortcuts
General
Function |
Key and/or Mouse |
Show Obj. Editor |
Ctrl+1 |
Dopesheet View |
Ctrl+2 |
Spline View |
Ctrl+3 |
Dope/Spline View |
Ctrl+4 |
Stage Tree
Function |
Key and/or Mouse |
Jump to Top Container |
Home |
Jump to Last Container |
End |
Move a page down in the tree |
Page Down |
Move a page up in the tree |
Page Up |
Scroll up the tree |
Cursor up |
Scroll down the tree |
Cursor down |
Jump to an item (Director, Actor, or Channel), in the tree |
Press the first letter of the item name |
Open or close the selected tree |
Return, or the numeric keyboard Return |
Stage Views
Function |
Key and/or Mouse |
Start/Continue Animation Forward |
Space |
Start Animation Backwards |
Shift+Enter |
Set Time-line Marker/Value to Start |
Ctrl+Home |
Set Time-line Marker/Value to End (not when infinity is selected) |
Ctrl+End |
Set View to 0 |
Home |
Set View to End director |
End |
Move the Time-line Marker one field |
<Ctrl> and the left or right arrow key |
Move the Time-line Marker more than one field at a time |
Left or right arrow key. This, for example, in 1080i50 format, moves the time-line marker 5 fields, left or right, and in 1080i60 the movement is 6 fields, left or right |
<Alt> and the left or right arrow key. This, for example, in 1080i50 format, moves the time-line marker 50 fields, left or right, and in 1080i60 the movement is 60 fields, left or right |
Delete Selected Key Frame(s) |
Delete |
Pan View |
Middle mouse click and drag |
Zoom Time Axis In or Out |
Mouse wheel |
Zoom Time Axis to Selected Channel |
Shift+Z, Shift+Y |
Zoom Time Axis to whole Animation |
Shift+X |
Zoom Spline/Dopesheet View In |
Mouse wheel, or Z, orY, orCtrl + Plus sign on the numeric keypad |
Zoom Spline/Dopesheet View Out |
Mouse wheel, orX, orCtrl + Minus sign on the numeric keypad |
Zoom Spline View to whole Spline |
Shift+A |
Zoom Time Axis and Spline View to view all Key Frames of selected Channel |
Shift+Q |
Zoom Time and Value Axis to View All Key Frames |
Shift+W |
Zoom Time Axis In/Out |
Z+Middle mouse click and drag |
Zoom Value Axis in Spline Editor In/Out |
A+Middle mouse click and drag |
Copy Selected Key Frame |
C+Left mouse click and drag |
Bring View to Time-line Marker |
M |
Reverse the Order of Selected Key Frames |
Ctrl+R |
Snap to Grid on/off |
Ctrl+G |
Set Time Axis to Seconds |
Ctrl+8 |
Set Time Axis to Frames |
Ctrl+9 |
Set Time Axis to Fields |
Ctrl+0 |
Move Time-line Marker to nearest Key Frame |
J |
Scale a Portion of Selected Director |
T+Left mouse click on Director Bar |
Rubber band Selection |
S+Left mouse click and drag |
Zoom in onto specific region |
Z+Left mouse click and drag |
Insert a new Stop Point |
S+Left mouse click on Director Bar |
View Spline 1 (Rotation Channel Only) |
Ctrl+Z |
View Spline 2 (Rotation Channel Only) |
Ctrl+X |
View Spline 3 (Rotation Channel Only) |
Ctrl+C |
Jump to next Key Frame |
Tab (a Key frame must be highlighted first) |
Jump to previous Key Frame |
Shift+Tab |
Escape from moving a Key Frame |
Esc |
