Mark Text
The Mark Text plug-in allows you to highlight or underline words in a text string.
Mark Text Properties
Text to Mark: Sets the text that should be highlighted. The text is case sensitive.
Multiple marks: Highlights all matched text.
Use regular expression: Allows regex to be used for more sophisticated highlighting.
Only matched group: Highlights only on capture-groups (value) , another matched texts outside capture-groups or inside non-capture-groups (?:value) will not.
Case insensitive: Matches both upper and lower case.
Grammar: Selects one of the following supported grammars:
ECMA
Basic
Extended
Awk
Grep
Egrep
Mark: Selects which text should be highlighted. Available options are foreground (Front), background (Shadow), Both and None. Background will highlight the text’s shadow.
Size: Sets the thickness of the highlight.
Position: Sets the y-position of the highlight in relation to the text.
Depth: Sets the z-position of the highlight in relation to the text. This allows the highlight to move behind the text.
Foreground Color: Sets the color and alpha value of the highlight.
To Mark Text
Add a group container to the scene tree and name it Text.
Add a font to the Text container.
Open the font editor and enter a text string.
Add the Mark Text plug-in to the Text container.
Open the Mark Text Editor and enter a word from your text string or regex if enabled.
From this example:
Text to mark: (?:the|a) (\w+)
Use regular expression: on
Only matched group: on
Case insensitive: on
Grammar: ECMA
Note: Do not change the font type between texture and geometry as this will not affect the whole string when using the Mark Text plug-in.
Note: Overlapping marks could occur with narrow character spacing or kerning. This would be visible in case of transparent marks.
