Recommendations
Viz Engine offers an open API to allow any control application to integrate with.
After installation of the software, please proceed with the following advisories:
  • Change the default User password. See Prerequisites.
  • Do not run Viz Engine with Administrator rights.
  • Disable Remote Access for WIBU Codemeter Webadmin and use SSL (Configuration > Basic > Webadmin).
  • Remove any unneeded services.
    • If FSmon and ArdFTP are not needed, do not install them.
    • Enable Viz Engine REST interface only if needed.
  • The recommended Nvidia driver should be used; however, new vulnerabilities can have been made public after the release of this software and it might be necessary to upgrade the Nvidia driver (see https://www.nvidia.com/en-us/security/ for details).
  • Do not expose any shares on the network.
