HP ZCentral 4R
This section describes the specification and PCIe board layout of a HP ZCentral 4R machine with the different cards provided by Vizrt.
Default Hardware
Server 1RU
OS: Windows 10 IoT Enterprise LTSC 2021
CPU : 1x Intel Xeon W-2235 6-Core
RAM : 32 GB DDR 4 (2x 16GB)
1st SSD : 512 GB M.2 on Mainboard
2nd SSD : 512 GB M.2 on Mainboard
RAID Controller : Intel Onboard
Hot Plug Power Supply : 2x 675W
Connectors
Front connectors |
Back connectors |
6. Primary PSU connector 7. Secondary PSU connector 8. Rear power button 9. Padlock loop 10. 1GbE RJ-45 (AMT) 11. 1/2.5/5/10GbE RJ-45 12. 4x USB 3.1 G1 Type-A 13. Single Slot Riser (1 PCIe G3 x16) 14. Dual Slot Riser |
Info: Slot 2 runs at Gen3 x8 Speed, if Slot 3 is loaded. |
PCIe Configuration with A4000
Slot |
Usage |
Slot 1 |
Graphics Card (Single Slot) |
Slot 2 |
Matrox Video Card (XMIO3, XMIO5, DSXLE4) or other PCIe card |
Slot 3 |
Matrox AES Audio or other PCIe card |
PCIe Configuration with A2000 or A5000
Slot |
Usage |
Slot 1 |
Slot 2 |
Graphics Card (Dual Slot) |
Slot 3 |
Info: Dual A4000 or Single A6000 GPU configurations will not run power redundant and are not tested by Vizrt.
BIOS Settings
During post, press F10 to access BIOS setup.
Click Advanced tab> Boot Options: Enable the Fast Boot .
Go back to Advanced tab > Secure Boot Configuration. Select Legacy Support Disable and Secure Boot Enable.
Go back to "Advanced tab > Build in Device Options \ Increase PCIe Idle Fan Speed to 0020.
Press ESC and save configuration.
Info: Certain third party vendor drivers require secure boot to be disabled to install properly.
