HP Z4 Rack G5
Slot Configuration
Slot |
Usage |
Slot 1 - Gen5 x16 |
Graphics Card (single Slot only) |
Slot 2 - Gen5 x16 or x8 |
Matrox Video Card (XMIO3, XMIO5, DSXLE4) |
Slot 3 - Gen5 x8 |
Other Expansion Card (Serial, GPI) |
Information: Matrox AES Audio can not be installed. Larger Graphic cards will not run in Power redundant mode and are not tested by Vizrt.
Default Hardware
Single CPU 10-Cores
Dual redundant Power
Supply 675W Platinum redundant, hot-swap
PCIe Gen5 Slots
Three PCIe Slots
64GB DDR5
1x 512GB M.2 (Front) + 1x 1TB M.2 (internal)
1x Gbit RJ45 onboard
1x 10Gbit RJ45 Flex IO Slot
GPU Support:
A4000
4000 Ada
Bios Settings
Security\Secure Boot Configuration Secure Boot: Enable
Advanced\Built-In Device Options: Increase PCIe Idle Fan Speed(%): 30
Advanced\Power Management Options:
Hardware P-States: Disable
S4/S5 Maximum Power Savings: Disable
PCI Express Power Management: Disable
Advanced\Performance Options: Workload Configuration: I/O-Focused
Advanced\Power Supply Options: Power Supply Mode: Redundant
