HP Z4 G5
Slot/Card Installation
Slot Configuration
Slot |
Usage |
Slot 1 Gen5 x16 |
Graphics Card |
Slot 2 Gen4 x8 (PCH) |
Free or used by Dual Slot GPU |
Slot 3 Gen4 x8 (PCH) |
Other Expansion Card (Serial, GPI) |
Slot 4 Gen4 x16 |
Matrox Video Card (XMIO3, XMIO5, DSXLE4) |
Slot 5 Gen4 x16 |
Default Hardware
Single CPU 10-Cores
Dual redundant Power Supply
675W Platinum redundant, hot-swap
PCIe Gen4+Gen5 Slots
5 PCIe Slots
64GB DDR5 1x512GB M.2 + 1x 1TB M.2
1x Gbit RJ45 onboard
1x 10Gbit RJ45 Flex IO
SlotGPU Support:
A2000
A4000
A5000
A6000
6000 Ada
Bios Settings
Security\Secure Boot Configuration Secure Boot: Enable
Advanced\Built-In Device Options: Increase PCIe Idle Fan Speed(%): 30
Advanced\Power Management Options:
Hardware P-States: Disable
S4/S5 Maximum Power Savings: Disable
PCI Express Power Management: Disable
Advanced\Performance Options: Workload Configuration: I/O-Focused
