Version 1.6 | Published December 15, 2022 ©
Configure the Studio
This section details how to configure Viz Virtual Studio.
Click Open to select a previously saved studio configuration, or create a new configuration by clicking Save As.
Set the Frequency frame rate. Available options are:
50 Hz
60 Hz
59.94 Hz
30 Hz
29.97 Hz
25 Hz
24 Hz
Set the Synchronization base:
Freerun: Does not synchronize. Tracking Hub runs using its own time base, corresponding with the configured frequency. This option should not be used in production environments.
AV-Card: Synchronizes using Plura PCL-PCI or PCL-PCIe sync cards.
Viz Engine: Synchronizes with a Viz Engine running on the same computer.
Go to Configure Topology.
