Version 2.1 | Published September 27, 2022 ©
Supported Codecs
The Channel Recorder supports the following containers and codecs.
Note: If a combination of CODEC / CONTAINER / RESOLUTION is not supported, Channel Recorder floods the logs with errors. If this happens stop the recording using RECORD STOP. Please make sure that the mentioned combination are supported by consulting the tables below.
Note: Only the containers AVCINTRAMXF, DVCPROMXF, XDCAMMXF, XAVCMXF support capturing of closed captions. The closed captions must be part of SMPTE 334M CDP. The captured close caption is found in the recorded clip in the wrapper according to SMPTE 436M and in the actual MXF essence.
Note: The examples below are not exhaustive. Some parameters such as the number of audio channels have other options.
PAL Codecs
MPEG-IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
MPEG2-IFrame422 720x576 |
Alpha: No |
No Audio PCM:
CONFIG SET CODEC IFrame |
Specifying this codec / container combination is not supported through MVCP. If this codec / container combination is required then the web interface can be used to configure Channel Recorder. When sending MVCP commands, however, the codec / container must not be specified via vtr.media.video.input.compression.type. |
DVCAM
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DV/DVCAM 4:2:0 720x576 |
Alpha: No |
No Audio PCM:
CONFIG SET CODEC DvCam |
.mov |
Alpha: No |
No Audio PCM:
.mxf |
Alpha: No |
No Audio |
Information: Video bitrate is 25, but the encoded bitrate is 28.75 (15% more) which includes other data.
DVCPRO
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DVCPRO 4:1:1 |
Alpha: No |
No Audio PCM:
CONFIG SET CODEC DvCPro |
.avi |
DVCPRO 50 4:2:2 |
Alpha: No |
No Audio PCM:
CONFIG SET CODEC Dv50 |
.mov |
DVCPRO 4:1:1 |
Alpha: No |
No Audio PCM:
.mov |
DVCPRO 50 4:2:2 |
Alpha: No |
No Audio PCM:
.mxf (OP1a) |
DVCPRO 4:1:1 |
Alpha: No |
PCM:
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.mpeg.bit_rate "25000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf (OP1a) |
DVCPRO 50 4:2:2 |
Alpha: No |
PCM:
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf Panasonic P2 (OP-Atom) |
DVCPRO 4:1:1 |
Alpha: No |
No Audio |
Specifying this codec / container combination is not supported through MVCP. If this codec / container combination is required then the web interface can be used to configure Channel Recorder. When sending MVCP commands, however, the codec / container must not be specified via vtr.media.video.input.compression.type |
DVCPRO 50 4:2:2 |
Alpha: No |
No Audio |
Information: Video bitrate is 25, but the encoded bitrate is 28.75 (15% more) which includes other data. The same applies for 50 bitrate. The encoded bitrate is 57.6 (15% more).
XDCAM
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX50) 4:2:2 |
Alpha: No |
AES3:
CONFIG SET CODEC XDCam |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1 |
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX40) 4:2:2 |
Alpha: No |
AES3:
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "40000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1 |
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX30) 4:2:2 |
Alpha: No |
AES3:
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "30000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1 |
NTSC Codecs
MPEG IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
MPEG2-IFrame422 720x480 |
Alpha: No |
No Audio PCM:
DVCAM
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DV/DVCAM 4:1:1 720x480 |
Alpha: No |
No Audio PCM:
.mov |
Alpha: No |
No Audio PCM:
Alpha: No |
No Audio |
DVCPRO
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DVCPRO 4:1:1 720x480 |
Alpha: No |
No Audio PCM:
.avi |
DVCPRO 50 4:2:2 720x480 |
Alpha: No |
No Audio PCM:
.mov |
Alpha: No |
No Audio PCM:
.mov |
Alpha: No |
No Audio PCM:
.mxf (OP1a) |
Alpha: No |
PCM:
.mxf (OP1a) |
Alpha: No |
PCM:
Alpha: No |
No Audio |
Alpha: No |
No Audio |
XDCAM
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX50) 4:2:2 720x512 |
Alpha: No |
AES3:
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX40) 4:2:2 720x512 |
Alpha: No |
AES3:
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX30) 4:2:2 720x512 |
Alpha: No |
AES3:
720p50 and 720p59.94 (60M) Codecs
MPEG-IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
MPEG2-IFrame422 1280x720 |
Alpha: No |
No Audio PCM:
DVCPRO HD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DVCPRO HD 1280x720 |
Alpha: No |
No Audio PCM:
.mov |
DVCPRO HD 960x720 |
Alpha: No |
No Audio PCM:
.mxf (OP1a) |
DVCPRO HD 960x720 |
Alpha: No |
PCM:
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
DVCPRO HD 960x720 |
Alpha: No |
No Audio |
XDCAM HD 422
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD 422 1280x720 |
Alpha: No |
No Audio PCM:
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2-ibp-422p@hl" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
XDCAM EX HQ
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM EX HQ 1280x720 |
Alpha: No |
No Audio PCM:
CONFIG SET CODEC XDCamEX |
AVC-Intra
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
AVCIntra Class 50 960x720 |
Alpha: No |
PCM:
CONFIG SET CODEC AVCIntra50 |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "avc-intra" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf (OP1a) |
AVCIntra Class 100 1280x720 |
Alpha: No |
PCM:
CONFIG SET CODEC AVCIntra100 |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "avc-intra" SET U1 MED vtr.media.mpeg.bit_rate "100000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
Alpha: No |
No Audio |
Alpha: No |
No Audio |
ProRes
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mov |
I-Frame 4:2:2 1280x720 |
Alpha: No |
No Audio PCM:
CONFIG SET CODEC ProRes |
DNxHD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
DNxHD (50) 120, 175 DNxHD (59.94) 145, 220 1280x720 |
Alpha: No |
No Audio PCM:
CONFIG SET CODEC DNxHD |
.mxf (OP1a) |
DNxHD (50) 175x DNxHD (59.94) 220x 1280x720 |
Alpha: No |
No Audio PCM:
Alpha: No |
No Audio |
Alpha: No |
No Audio |
XAVC
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XAVC |
Alpha: No |
PCM:
CONFIG SET CODEC XAVC |
Note: The configuration v210 must be enabled in the configuration section for recording XAVC.
1080i25 and 1080i29.97 (30M) Codecs
MPEG-IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
MPEG2-IFrame422 1920x1080 |
Alpha: No |
No Audio PCM:
DVCPRO HD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DVCPRO HD (25) 1920x1080 DVCPRO HD (29.97) 1260x1080 |
Alpha: No |
No Audio PCM:
.mov |
Alpha: No |
No Audio PCM:
Alpha: No |
No Audio |
.mxf (OP1a) |
Alpha: No |
PCM:
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.mpeg.bit_rate "100000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
Information: Video bitrate is 100, but the encoded bitrate is 115 (15% more) which includes other data.
XDCAM HD 422
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD 422 1920x1080 |
Alpha: No |
No Audio PCM:
XDCAM HD LP
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD LP 1440x1080 |
Alpha: No |
No Audio PCM:
CONFIG SET CODEC XDCamHD |
XDCAM HD SP
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD SP 1440x1080 |
Alpha: No |
No Audio PCM:
XDCAM HD HQ
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD HQ 1440x1080 |
Alpha: No |
No Audio PCM:
XDCAM EX HQ
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM EX HQ 1920x1080 |
Alpha: No |
No Audio PCM:
AVC-Intra
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
AVCIntra Class 50 1440x1080 |
Alpha: No |
PCM:
.mxf (OP1a) |
AVCIntra Class 100 1920x1080 |
Alpha: No |
PCM:
Alpha: No |
No Audio |
Alpha: No |
No Audio |
ProRes
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mov |
I-Frame 4:2:2 1920x1080 |
Alpha: No |
No Audio PCM:
DNxHD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
DNxHD (30) 120, 185 DNxHD (29.97) 145, 220 1920x1080 |
Alpha: No |
No Audio PCM:
.mxf (OP1a) |
DNxHD (30) 185x DNxHD (29.97) 220x 1920x1080 |
Alpha: No |
No Audio PCM:
Alpha: No |
No Audio |
Alpha: No |
No Audio |
XAVC
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XAVC |
Alpha: No |
PCM:
1080p50 and 1080p59.94 (60M) Codecs
AVC-Intra
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
Alpha: No |
PCM:
.mxf (OP1a) |
Alpha: No |
PCM:
Alpha: No |
No Audio |
Alpha: No |
No Audio |
MPEG-IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
Alpha: No Bitrate: 50-300 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC: No |
No Audio PCM:
ProRes
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mov |
Alpha: No |
No Audio PCM:
DNxHD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
DNxHD (50) 240, 365 DNxHD (59.94) 290, 440 1920x1080 |
Alpha: No |
No Audio PCM:
.mxf (OP1a) |
DNxHD (50) 365x DNxHD (59.94) 440x 1920x1080 |
Alpha: No |
No Audio PCM:
Alpha: No |
No Audio |
Alpha: No |
No Audio |
XAVC
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XAVC |
Alpha: No |
PCM:
2160p50 and 2160p59.94 (60M) Codecs
XAVC
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XAVC |
Alpha: No |
PCM:
Note: A M264 board is recommended for recording UHD.
Note: The configuration uhd and v210 must be enabled in the configuration section for recording UHD.
