Version 2.1 | Published September 27, 2022 ©
Crash Recording
Channel Recorder can be used to instantly record any input signal into a clip file. The delay between command and first field written to the file is usually less than four fields.
An example of how to invoke crash recording with MVCP command would be the following:
UADD CS_ENCODER1 * SHAR CaptureLOAD U1 "MVCP_Crash" IN CRTE NOEXCUER U1REC U1USTA U1STOP U1UNLD U1UCLS U1BYEAn example of how to invoke crash recording with regular Channel Recorder Commands:
RECORD CLIP Crash.mxfRECORD STARTRECORD STOPBoth examples create an instant recording (also called a crash recording) using the values in the configuration file.
