Viz Plug-ins User Guide
Control Hide in Range
The Control Hide in Range plug-in hides or shows a container if the input value given by the user is within or outside a specified value range. The input value must be from a font container that holds a numeric value, typically with a Control Num plug-in.
Control Hide in Range Properties
Input Value: Shows the current input value.
Lower Range Bound: Sets the upper bound for the range.
Upper Range Bound: Sets the lower bound for the range.
Visibility in Range: Sets whether the container should be visible or hidden when the input value is within the range.
