Viz World Classic User Guide
Path Tool
Allows you to edit the animation path along which a map layer, image, text item, or drawing is animated.
To Change the Animation Path
Point to a point on the animation path. The cursor changes to a triangle.
Drag the point with the mouse pointer.
To Change the Curvature of the Animation Path
Hold down CTRL and drag from a point on the animation path to extend tangent handles from that point.
To Move the Tangent Handles Independently
Hold down CTRL and drag one tangent handle.
