Viz World Classic User Guide
Defining the Properties of the Entire Text Layer
In addition to being able to define the properties of individual text items, the Properties panel allows you to edit properties for an entire text layer.
Compositing Options
Blend Mode specifies how the layer is combined with the other layers, and can be one of:
Normal, Add, Subtract, Difference, Multiply, Darken Only, Burn, Color Burn, Screen, Lighten Only, Dodge, Color Dodge, Hue, Saturation, Value, Color, Overlay, Soft Light, Hard Light, Pin Light, Exclusion, or Negation.
The Opacity determines the layer opacity, and can be animated.
Animation Options
Allows you to animate the entire text layer. The options are the same as for individual text items.
