Version 5.6 | Published July 22, 2024 ©
tr_transition
The table tr_transition contains the transition types available for Mosart templates. A transition is defined as the transition to take when taking a template (i.e. the transition from the former template).
| Name | Type | Allow Null | Description |
| tr_recno | integer | No | Primary key. |
| tr_name | varchar(32) | No | The transition name. |
| tr_description | varchar(128) | Yes | Optional transition description. |
| tr_fi_recno | integer | Yes | Optional foreign key referencing an input field, fi_recno in the fi_field table. |
