Version 5.6 | Published July 22, 2024 ©
ScreenLL Configuration File
The ScreenLL configuration file is named ClipServerScreenLL.xml.
<?xml version="1.0" encoding="utf-8" ?> <MediaServerConfig xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">   <Properties>     <!-- Language code to look for to decide clip availability -->     <item name="AvailabilityLanguageCode" value="OPN" />     <!-- First Incue Time code that indicates invalidated clip -->     <item name="InvalidatedFirstIncueTime" value="--:--:--:--" />   </Properties> </MediaServerConfig>Properties
AvailabilityLanguageCode: Specifies which language code must be present in order for a clip to be marked as available. The language code is a three letter text string, which relates to a list of language codes found in the file PoliSTLServerLangs.lst, which must be present on the ScreenLL subtitle file server.
InvalidatedFirstIncueTime: Specifies the First Incue Time value that will indicate that a subtitle clip has been invalidated (is not available even if it matches the AvailabilityLanguageCode).
Other configuration items are customer-specific or for Vizrt internal use only.
