Viz Vectar Plus User Guide
Version 1.2 | Published April 12, 2022 ©
Keyboard Shortcuts
Switcher
Shortcut |
Action |
F1 - F12 and |
Program Row, Inputs 1 to 24 |
1 – 0, -, =, and |
Preview Row, Inputs 1 to 24 |
Transition Delegate – select BKGD |
SHIFT + [ |
Transition Delegate – multi-select BKGD |
Transition Delegate – select DSK 1 |
SHIFT + ] |
Transition Delegate – multi-select DSK 1 |
Transition Delegate – select DSK 2 |
SHIFT + \ |
Transition Delegate – multi-select DSK 2 |
BACKSPACE |
Transition Delegate – select DSK 3 |
SHIFT + BACKSPACE |
Transition Delegate – multi-select DSK 3 |
INSERT |
Transition Delegate – select DSK 4 |
SHIFT + INSERT |
Transition Delegate – multi-select DSK 4 |
B |
Transition Delegate – select FTB |
CTRL + B |
Select FTB Delegate and perform Fade |
A |
Auto DSK 1 On/Off |
S |
Auto DSK 2 On/Off |
D |
Auto DSK 3 On/Off |
F |
Auto DSK 4 On/Off |
SHIFT + A |
Take DSK 1 On/Off |
SHIFT + S |
Take DSK 2 On/Off |
SHIFT + D |
Take DSK 3 On/Off |
SHIFT + F |
Take DSK 4 On/Off |
, and . |
Select Transition (prev/next) |
CTRL + F |
Select Fade Transition |
SHIFT + CTRL + F |
Restore Last Transition |
Z |
Slow Transition – Slow … Medium … Fast |
X |
Medium Transition |
C |
Fast Transition |
SHIFT + C |
Transition – Increase Speed |
SHIFT + Z |
Transition – Decrease Speed |
E |
Toggle Reverse Transition On/Off |
ALT + E |
Ping Pong Transition (off/on) |
T-Bar
Shortcut |
Action |
ENTER |
Take |
SHIFT + ENTER |
Take T-bar Back to Top |
SPACE |
Transition … Go/Pause |
SHIFT + SPACE |
Auto Reverse |
T / SHIFT + T (faster add CTRL) |
Adjust T-bar… Down/Up |
H |
Halfway T-bar… Take |
Record, Grab, and Stream
Shortcut |
Action |
R / SHIFT + R |
Record on/off |
P |
Grab (still image) p |
CTRL + / |
Stream Start |
CTRL + ALT + / |
Stream Stop |
Tabs
Shortcut |
Action |
CTRL + (F1 to Fn) |
Show (DDR, PTZ, Mixer, etc.) tab |
CTRL + SHIFT + F1-F8 |
Select M/E 1- 8 |
CTRL + M |
Show M/E pane |
ALT + M |
Hide M/E pane |
M |
Toggle M/E pane |
Workspace
Shortcut |
Action |
ALT + Numpad 0 |
Show Interface A |
ALT + Numpad 1 |
Show Interface B |
ALT + Numpad 2 |
Show Interface C |
ALT + Numpad 3 |
Show Interface D |
CTRL + Numpad 0 |
Show Multiview A |
CTRL + Numpad 1 |
Show Multiview B |
CTRL + Numpad 2 |
Show Multiview C |
CTRL + Numpad 3 |
Show Multiview D |
Media Players
Shortcut |
Action |
K |
Stop |
L |
Play |
J |
Go to previous playlist item |
Go to next playlist item |
U |
Autoplay On/Off |
Loop On/Off |
Q |
Single On/Off |
UP/DOWN/LEFT/RIGHT |
Navigate through Playlist items |
I |
Set In Point for current Playlist Item (Clip or Audio file) |
O |
Set Out Point for current Playlist Item (Clip or Audio file) |
G |
Split clip at current frame / Reset In and Out Point to the file’s first and last frame |
General
Edit Title Pane
Shortcut |
Action |
CTRL + SHIFT + S |
Save the current title page |
CTRL + SHIFT + S |
Save the current title page, and duplicate it in the playlist |
PAGE UP |
Save the page and move to the previous playlist item |
PAGE DOWN |
Save the page and move to the next playlist item |
Miscellaneous
Shortcut |
Action |
CTRL + X |
Cut |
CTRL + C |
Copy |
CTRL + V |
Paste |
DELETE |
Delete |
ALT + B |
Show version |
