Viz Ticker User Guide
To Import Viz Artist 3 Example Scenes
Start Viz Artist 3.
From the Main menu, click Import.
In the Import panel that appears, browse to the example files in the installation directory of Ticker Wizard. The files can be found at <Installation-Directory>\examples. See Installation Directories.
Make sure that Archives to Import is selected in the drop-down list at the top of the Import panel. The Import panel then shows all available archives that can be imported from the selected folder.
Select the Viz3_Examples.via archive.
Click the Import Archive button. The archive is imported and available from the list of scenes in Viz Artist. The archive contains various scenes; one flipping carousel example, and one scrolling carousel example.
