Viz Ticker User Guide
About Logging
The Ticker System Tool supports logging. By default, the system logs to a file and to the console. This logging can be configured, if needed.
Logging Configuration File
The default configuration for the logging can be found in TickerSystemTool.exe.config, located in the same folder as the Ticker System Tool program files (for more details, see To Install the Ticker System Tool). The logging configuration can be modified by editing this .config file.
Console Logging
Log information can be sent to the console. A convenience flag (silent/verbose) adjusts the console logging. For example, if invoking the Ticker System Tool from a script, it might be appropriate to use the silent option. For more details, see Generic Ticker System Tool Commands.
Colors are used to distinguish between various log levels. For example, red is used for errors, yellow for warnings, gray for information, and so on.
Log Files
Ticker System Tool log files are created and stored in the same location as all the other Viz Ticker system applications’ log files (for more details, see System Log Files).
Example: %AppData%\Vizrt\TickerSystemTool\log\TickerSystemTool-yyyy-MM-dd.log
By default, a 14 day log rotation is applied.
External Components License
The Ticker System Tool uses the NLog logging platform to produce log details. The following NLog copyright details apply:
Copyright (c)
2004
2016
Jaroslaw Kowalski <jaak
@jkowalski
.net>, Kim Christensen, Julian Verdurmen
All rights reserved.
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice,
this
list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice,
this
list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
* Neither the name of Jaroslaw Kowalski nor the names of its contributors may be used to endorse or promote products derived from
this
software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
"AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
