Viz Ticker User Guide
Listing and Triggering Actions
The generic API call format to list all Ticker actions is:
GET http:
//[host]:[port]/actions
Example
curl -X GET http:
//localhost:8580/actions
Receive formatted XML:
curl -X GET http:
//127.0.0.1:8580/actions/ | tidy -xml -i -w 0
Controlling the Ticker Actions with REST Calls
Assuming you have a Ticker on program with a Ticker carousel named NEWS you can switch the system On with:
curl -X POST http:
//localhost:8580/actions/Main%20ticker%20system%20on curl -X POST http://localhost:8580/actions/Main%20program%20on curl -X POST http://localhost:8580/actions/Main%20NEWS%20in
And you can turn the ticker Off with:
curl -X POST http:
//localhost:8580/actions/Main%20NEWS%20out curl -X POST http://localhost:8580/actions/Main%20program%20off curl -X POST http://localhost:8580/actions/Main%20ticker%20system%20off
An alternative to curl is to use a browser to parse the received XML for actions, as illustrated in the screenshot below using Firefox:
