Viz Ticker User Guide
Installing Ticker Feed
Note: If Ticker Feed is already installed on the machine, you must first remove the old program version before installing the new one, see To uninstall Ticker Feed, see below.
Run TickerFeed-<Product Version>.msi.
Follow the on-screen instructions. Ticker Feed is now installed on the machine at the defined location.
Select Start > Control Panel > Programs > Uninstall a program. Ticker Feed is no longer available on the machine.
Note: The software settings are not deleted with the software.
