Viz Ticker User Guide
Keyboard Shortcuts
The following keyboard shortcuts can be used to operate Viz Ticker:
Viz Ticker Client and Ticker Wizard
Function |
Key + Mouse Combination |
Select the next tab in the Main Menu |
CTRL + TAB |
Viz Ticker Client’s Pool Frame
Function |
Jump to the Pool Search text box |
CTRL + F |
Copy currently selected messages |
CTRL + C |
Cut currently selected messages |
CTRL + X |
Delete currently selected messages |
DELETE |
Open a new message in Elements Editor based on the default template |
CTRL + N |
Open the Select Template dialog box, where any available message template can be selected |
CTRL + T |
Paste messages |
CTRL + V |
Select all messages |
CTRL + A |
Viz Ticker Client’s Carousel Frame
Function |
Activate the Find text box in the Carousel Search |
CTRL + F |
Activate currently selected messages |
INSERT |
Deactivate currently selected messages |
CTRL + INSERT |
DELETE |
CTRL + C |
CTRL + X |
Paste messages |
CTRL + V |
CTRL + A |
Viz Ticker Client’s Elements Editor
Function |
Save the current element |
CTRL + S |
