Viz Ticker User Guide
System Applications
Various applications make up the Ticker System:
Application |
Description |
The Vizrt Ticker client application, for operating and providing data to defined tickers. In this system, messages are created, added to a carousel, and sent to air. The typical user of Viz Ticker Client is a journalist or operator. |
The Vizrt Ticker configuration application for importing scenes created in Viz Artist and creating tickers. In this system, carousels are selected and equipped with templates. Adjustments of the GUI settings in Viz Ticker Client can also be defined from this system. The typical user of Ticker Wizard is a graphical artist. |
A service for connecting external feeds to a Ticker System. It makes it possible to populate a scrolling or flipping carousel with data elements from a file that is updated from an external source. It is optional to include this component in the Viz Ticker setup. |
A component responsible for communicating ticker messages to the Viz Engine renderer. This component is necessary in order to run a scrolling carousel in Viz Ticker. |
A console application that performs various important system operations, such as archiving (export/import), upgrading and system deletion. |
