Viz Ticker User Guide
Begin and End Times from Ticker Feed
Problem
Can I set the begin/end times for messages in the Ticker Feed source XML and then view/edit it in Viz Ticker Client?
Solution
It is not recommend to use Viz Ticker Client to edit messages controlled by Ticker Feed since manual changes are overridden on the next Ticker Feed update. Furthermore, Start/End time may show incorrectly in the UI when setting the begin/end elements in the Ticker Feed source XML since the UI can only be used to visualize certain begin/end combinations.
