 Viz Multichannel
Version 4.2 | Published July 31, 2020 ©
PUT on Primary Event in Playlist (Version 2.0)
Update a Primary Event definition.
Syntax
PUT /api/channels/test/playlists/[playlist_id]/primaryevents/[primary_event_id]Request
PUT /api/channels/test/playlists/continuous/primaryevents/1051111_1_VM_16_01_1 HTTP/1.1Content-Type: application/atom+xml; type=entry<atom:entry xmlns:vaext="http://www.vizrt.com/atom-ext" xmlns:vizid="http://www.vizrt.com/opensearch/vizid" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:inthub="http://www.vizrt.com/integrationshub" xmlns="http://www.w3.org/2007/app" xmlns:atom="http://www.w3.org/2005/Atom">   <inthub:name>1051111_1_VM_16_01_1</inthub:name>   <atom:id>1051111_1_VM_16_01_1</atom:id>   <atom:meta_data>       <atom:attribute name="continue_count">0</atom:attribute>       <atom:attribute name="created">6/11/2018 17:33:51</atom:attribute>       <atom:attribute name="date">2010-09-23</atom:attribute>       <atom:attribute name="fixed_duration">yes</atom:attribute>       <atom:attribute name="seqment">1</atom:attribute>       <atom:attribute name="time">08:50:15:24</atom:attribute>   </atom:meta_data>   <inthub:description>In-channel trailer - Updated Title</inthub:description>   <inthub:begin_at>2018-11-06T07:13:40.000Z</inthub:begin_at>   <inthub:duration>00:00:35:00</inthub:duration>   <inthub:ignore>False</inthub:ignore>   <inthub:event_id>1051111_1_VM_16_01_1</inthub:event_id>   <inthub:trigger_id>primary1001</inthub:trigger_id>   <inthub:instance>composite_test</inthub:instance>   <inthub:adjust_begin_at_after_resume>yes</inthub:adjust_begin_at_after_resume></atom:entry>Response
HTTP/1.1 200 OKContent-Type: application/atom+xml; type=entry<atom:entry xmlns:vaext="http://www.vizrt.com/atom-ext" xmlns:vizid="http://www.vizrt.com/opensearch/vizid" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:inthub="http://www.vizrt.com/integrationshub" xmlns="http://www.w3.org/2007/app" xmlns:atom="http://www.w3.org/2005/Atom">	<inthub:name>1051111_1_VM_16_01_1</inthub:name>	<atom:id>1051111_1_VM_16_01_1</atom:id>	<atom:link rel="self" type="application/atom+xml; type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1051111_1_VM_16_01_1" />	<atom:link rel="edit" type="application/atom+xml; type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1051111_1_VM_16_01_1" />	<atom:link rel="secondaryevents" type="application/atom+xml; type=feed" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1051111_1_VM_16_01_1/secondaryevents" />	<atom:meta_data>		<atom:attribute name="continue_count">0</atom:attribute>		<atom:attribute name="created">6/11/2018 17:33:51</atom:attribute>		<atom:attribute name="date">2010-09-23</atom:attribute>		<atom:attribute name="fixed_duration">yes</atom:attribute>		<atom:attribute name="seqment">1</atom:attribute>		<atom:attribute name="time">08:50:15:24</atom:attribute>	</atom:meta_data>	<inthub:description>In-channel trailer - Updated Title</inthub:description>	<inthub:begin_at>2018-11-06T07:13:40.000Z</inthub:begin_at>	<inthub:duration>00:00:35:00</inthub:duration>	<inthub:ignore>False</inthub:ignore>	<inthub:event_id>1051111_1_VM_16_01_1</inthub:event_id>	<inthub:trigger_id>primary1001</inthub:trigger_id>	<inthub:house_id />	<inthub:instance>composite_test</inthub:instance>	<inthub:adjust_begin_at_after_resume>yes</inthub:adjust_begin_at_after_resume>	<inthub:infoIntegrationsHub>[U:23:41:36]</inthub:infoIntegrationsHub></atom:entry>Note
If doing a PUT against a URI that doesn't represent an existing Primary Event, the response is 'HTTP/1.1 404 PrimaryEvent 'primary_event_id' not found for playlist 'playlist_name' in channel 'channel_name'' and no element is updated.
