Mosart Web Applications Guide
Version 1.6 | Published August 10, 2023 ©
Working with the Rundown Viewer
Key Features
The Mosart Rundown Viewer provides a convenient, browser based display of a Viz Mosart rundown.
Note: To browse a rundown in Rundown Viewer, a standard Viz Mosart setup must first be running with a loaded rundown. See section Setup and Administration.
Opening the Rundown Viewer
You access the Mosart Rundown Viewer from the Mosart Web Applications Configuration Tool.
To open the Mosart Rundown Viewer
Start the Mosart Web Applications Configuration Tool.
This is either a Desktop shortcut
or accessed from the Windows Start menu by typing Mosart Web Applications. -
From the Rundown Viewer panel, click Open.
The Mosart Rundown Viewer displays in your default web browser.
For a explanation of the elements in a Viz Mosart rundown, please refer to the Viz Mosart User Guide, under User Interface, the section Rundown Window.
Story Scaler
You can expand the viewing area for items in a story row. This is useful to see full text details on an item.
Adjust the Story scaling slider to desired column width.
Go to On Air Story
A navigation button
enables immediate scrolling to the current on-air story.
