Viz Engine
Install the Viz License
Viz Artist/Engine must have a license to operate. A license is normally acquired when the product is purchased. To get additional or updated licenses, contact your local Vizrt representative.
Note: Some of the installed plug-ins are licensed separately.
To Apply a Viz License in the GUI
Use this procedure to apply a first time license, apply a new license after a license expiry, or apply a new license before a license expires.
Make sure that the date and time on the computer is correct. The license is only valid for a certain time frame.
Insert the License dongle.
Start Viz Engine or Viz Artist.
Open the License window:
If this is a first time license application or the license has expired, the License window will open.
If this is a new license application before a license expiry date, click on the License Information button.
Check that the Dongle ID, in the License Information text file, is the same as the System ID in the License window.
Check these details:
Check that the license string has 32 pairs of characters and that they are divided by a single space.
Check the characters and for spaces at the end.
Copy the license string from the License Information text file.
Paste the license string in the License field of the License window.
Check that the license key has not been entered twice.
Check that the whole string is pasted.
Click Apply New License.
Restart for the changes to take effect.
To Apply a Viz License in Viz Configuration
Use this procedure to apply new license before a license expires.
Open Viz Configuration.
Click on Viz License Information.
Check that the Dongle ID, in the License Information text file, is the same as the System ID in the Viz License Information panel.
Check these License details:
Paste the license string in the License field of the Viz License Information panel.
Press <ENTER>.
Click Save.
To Apply a Viz License with the Viz Console
Start Viz Engine, Viz Artist or Viz Config.
In the Viz Console enter the text send KEY SET [full license string].
Tip: In Viz Artist or Viz Engine, click on
 to view the Viz console.
Press <Enter>.
Restart Viz Artist/Engine for the changes to take effect.
