GET a Template from Template Pool (Version 2.0)
Get a template from the templates pool in a channel .
Syntax
GET /api/channels/[channel]/templates/[template]Request
GET /api/channels/test/templates/4000 HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/vizrt.integrationshubv2+xml; type=mastertemplate<inthub:masterTemplate xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:inthub="http://www.vizrt.com/integrationshub"> <inthub:name>4000</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=mastertemplate" href="http://localhost:9991/api/channels/test/templates/4000" /> <inthub:concept>SD</inthub:concept> <inthub:updated>2023-12-12T15:21:06Z</inthub:updated> <inthub:importDatetime>2021-12-10T23:04:53.918Z</inthub:importDatetime> <inthub:layer>/ChannelBranding/channels/test/templates/sceneselectors/4000</inthub:layer></inthub:masterTemplate>Disallowed Actions
This end-point does not allow POST, PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
