GET Primary Events in Playlist (Version 2.0)
By following the downlink from the description of a single playlist we can retrieve a collection of primary events.
Take note that the collection of primary events contains a compact version of a Primary Event. Use the downlink for each Primary Event to get details.
Syntax
GET /api/channels/[channel]/playlists/[playlist]/primaryeventsRequest
GET /api/channels/test/playlists/continuous/primaryevents HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/vizrt.integrationshubv2+xml; type=list<inthub:list xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="inthub:primaryEventsCompact" xmlns:inthub="http://www.vizrt.com/integrationshub"> <inthub:primaryEventCompact> <inthub:name>primary_element_1_0_0</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=primaryevent" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0" /> <inthub:refLink rel="secondaryevents" type="application/vizrt.integrationshubv2+xml; type=list" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0/secondaryevents" /> <inthub:description>Le radeau LE CRASH DU VOL 29</inthub:description> <inthub:startTime>2008-04-23T03:48:17.280Z</inthub:startTime> <inthub:duration>08:58:13.000</inthub:duration> <inthub:ignore>false</inthub:ignore> <inthub:triggerId /> <inthub:houseId /> <inthub:isLocked>false</inthub:isLocked> <inthub:isLive>false</inthub:isLive> <inthub:isManuallyEdited>false</inthub:isManuallyEdited> <inthub:available>1.00</inthub:available> <inthub:loaded>1.00</inthub:loaded> <inthub:infoIntegrationsHub>[A:11:47:44]</inthub:infoIntegrationsHub> <inthub:createdBy>schedule</inthub:createdBy> <inthub:error /> </inthub:primaryEventCompact> <inthub:primaryEventCompact> <inthub:name>primary_element_2_0_0</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=primaryevent" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_2_0_0" /> <inthub:refLink rel="secondaryevents" type="application/vizrt.integrationshubv2+xml; type=list" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_2_0_0/secondaryevents" /> <inthub:description>Flicka</inthub:description> <inthub:startTime>2008-04-23T04:15:54.160Z</inthub:startTime> <inthub:duration>37:49:25.000</inthub:duration> <inthub:ignore>false</inthub:ignore> <inthub:triggerId /> <inthub:houseId /> <inthub:isLocked>false</inthub:isLocked> <inthub:isLive>false</inthub:isLive> <inthub:isManuallyEdited>false</inthub:isManuallyEdited> <inthub:available>1.00</inthub:available> <inthub:loaded>1.00</inthub:loaded> <inthub:infoIntegrationsHub>[A:11:47:44]</inthub:infoIntegrationsHub> <inthub:createdBy>schedule</inthub:createdBy> <inthub:error /> </inthub:primaryEventCompact></inthub:list> Disallowed Actions
This end-point does not allow PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
