Stage Shortcuts
General
Function
Key and/or Mouse Shortcut
Shows Object Editor
CTRL + 1
Shows Dopesheet View
CTRL + 2
SHIFT + PAGE DOWN (on stage view focus)
Shows Spline View
CTRL + 3
SHIFT + PAGE UP (on stage view focus)
Shows Dope/Spline View
CTRL + 4
Stage Tree
Function
Jumps to Top Container
HOME
Jumps to Last Container
END
Moves a page down in the tree
PAGE DOWN
Moves a page up in the tree
PAGE UP
Scrolls up the tree
Cursor up
Scrolls down the tree
Cursor down
Jumps to an item (Director, Actor, or Channel), in the tree
Press the first letter of the item name
Opens or closes the selected tree
+ or Right arrow
- or Left arrow
Group Directors
SHIFT + D
Ungroup Directors
CTRL + SHIFT + D
Stage Views
Function
Starts/Continues Animation Forward
SPACE
Starts Animation Backwards
SHIFT + ENTER
Sets Time-line Marker/Value to Start
CTRL + HOME
Sets Time-line Marker/Value to End (not when infinity is selected)
CTRL + END
Sets View to 0
HOME
Sets View to End director
END
Moves the Time-line Marker one field
CTRL + the left or right arrow key
Moves the Time-line Marker more than one field at a time
Left or right arrow key. This, for example, in 1080i50 format, moves the time-line marker five fields, left or right, and in 1080i60 the movement is six fields, left or right.
ALT + LEFT ARROW/RIGHT ARROW. This, for example, in 1080i50 format, moves the time-line marker 50 fields, left or right, and in 1080i60 the movement is 60 fields, left or right
Deletes Selected Key Frame(s)
DELETE
Pans View
Middle mouse click and drag
Zooms Time Axis In or Out
Mouse wheel
Zooms Time Axis to Selected Channel
SHIFT + Z
SHIFT + Y
Zooms Time Axis to whole Animation
SHIFT + X
Zooms Spline/Dopesheet View In
Mouse wheel
Z/Y
CTRL + Plus sign on the numeric keypad
Zooms Spline/Dopesheet View Out
Mouse wheel
X
CTRL + Minus sign on the numeric keypad
Zooms Spline View to whole Spline
SHIFT + A
Zooms Time Axis and Spline View to view all Key Frames of selected Channel
SHIFT + Q
Zooms Time and Value Axis to View All Key Frames
SHIFT + W
Zooms Time Axis In/Out
Z + Middle mouse click and drag
Zooms Value Axis in Spline Editor In/Out
A + Middle mouse click and drag
Copies Selected Key Frame
C + Left mouse click and drag
Brings View to Time-line Marker
M
Reverses the Order of Selected Key Frames
CTRL + R
Snaps to Grid on/off
CTRL + G
Sets Time Axis to Seconds
CTRL + 8
Sets Time Axis to Frames
CTRL + 9
Sets Time Axis to Fields
CTRL + 0
Moves Time-line Marker to nearest Key Frame
J
Scales a Portion of Selected Director
T + Left mouse click on Director Bar
This shows a region where Key Frames can be scaled.
Provides Rubber band Selection
S + Left mouse click and drag
Zooms in onto specific region
Z + Left mouse click and drag
Inserts a new Stop Point
S + Left mouse click on Director Bar
Jumps to next Key Frame
TAB (a Key frame must be highlighted first)
Jumps to previous Key Frame
SHIFT + TAB
Escapes from moving a Key Frame
ESC
