Control Objects
The Control Objects panel is used to show the control parameters for control applications like Viz Trio or Viz Pilot only.
images/download/attachments/149924522/image2023-5-10_13-51-39.png
Control Object Parameters
Control Objects are defined by adding certain plug-ins, so called Control Objects to containers. These plug-ins expose certain functionality to Control Applications like Viz Pilot or Viz Trio. Every Control plug-in must have a Control Object plug-in in the upper hierarchy of the scene tree.
Fields: A unique field identifier of this property. This is shown in the control applications. The following characters are allowed to guarantee compatibility with other control applications:
    • - , _ , .
    • 0 - 9
    • a - z
    • A - Z
  • Description: Enter a description in the plug-in Properties panel.
  • Value: The editable plug-in value. This value is then overwritten by the operator in the control room.
  • Type: The type of Control Object.
  • Minimum and Maximum values: Used for Integer and Float values.
ControlList structures are shown as expandable groups within the editor:
images/download/thumbnails/149924522/image-2023-6-13_10-5-52.png
