Texture Renderer
The texture renderer has two types: Substance Texture Renderer and Preprocessing Texture Renderer.
Substance Texture Renderer is responsible for manipulating Substance material textures, while Preprocessing Texture Renderer processes a single texture using a basic set of effects.
Please see the details at Substance Materials.
To use this type of texture renderer, click on Add button and select Preprocessing Texture Renderer. This creates a workspace object with the blue PP tag at the right bottom.
images/download/thumbnails/125467610/pic-1.png
Double click on it, and the Workspace dock shows the properties of the texture renderer. After that, drag and drop a texture in the Source Texture box.
images/download/thumbnails/125467610/pic-2.png
Alternatively, drag an image asset from Asset View to the Texture Renderer Workspace.
images/download/attachments/125467610/pic-3.png
To apply the texture renderer to the container, either drag the texture renderer to any texture input box in a material or Texture Slot, or drag it to the container in Scene Tree dock. The latter automatically creates an unlit Phong material using the texture as a Base Color for that container.
images/download/attachments/125467610/pic-4.png
Info: A texture renderer can also be dragged into Scene Editor to make a quad with the texture renderer applied.
  • In case of a Substance texture renderer, a PBR material will be created for the quad.
  • In case of a Preprocessing texture renderer, an unlit Phong material will be created for the quad.
Using Effects
Currently there is only one effect available: Blur. To adjust the effect, double click in the texture renderer to examine its properties. The effect can be adjusted from 0% to 100%.
images/download/attachments/125467610/pic-5.png
Note that changing the values affects the container using it in real-time.
Animating Effects
To animate the effect, open the Stage dock and find a director where the texture renderer is going to be manipulated. After that, drag the texture renderer to the director to create the actor for the texture renderer.
images/download/attachments/125467610/pic-6.png
Right click on the actor, select Preprocessing and choose the effect to be animated. There are a set of keyframes initialized. See further details about how to manipulate an animation at The Stage for Animation.
